Discovery Import
Discovery Import
Replace reference error
    • rg
      Why after the save as of the component in one of sub-assembly the reference is missing?
      Regards
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Naresh Patre
      Hello Roberto
      Is it possible for you to share the assembly (and all its sub assemblies) that you shown in the video, for investigating this issue?
      • rg
        Naresh Patre
        we can send them to you, the subgroups have all been created by the same component
    • Naresh Patre
      Hello Roberto Can you attach the model(s) here? I guess those are generic and can be uploaded here. If not, let me know and I will send you a separate link for uploading.
    • rg
      Hi, I can attach them right away.
      Thank you
      🛈This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      • Naresh Patre
        Roberto
        Thanks for sharing the model. The reason behind this failure is that component 2 is actually a copy of component 1. Unlike component1 which is a separate scdoc file, component 2 is not a separate file. If you have component2 as a separate file, then the saving will work fine. I have created a similar test case to demonstrate this behavior. In the attached model, if you follow the same steps as you shown in the video, you can see that component2 gets saved with a new name and is also reflected in both the assemblies of the main file.
    • mc
      Naresh Patre Brian Bueno Marco Ugolotti Subashni
      Roberto
      Hello Naresh,
      thank you for your answer but ... I'm sorry I can't be agree with you.
      - First of all in the previously version the behavior was correct and not like now.
      - Second, even if a component is a copy of another one is not possible that the software "destroys" the assembly references and leave a message saying that there was an assembly....or the software makes the replacing in right way or at least does nothing ... but cannot make damages!!
      • Naresh Patre
        Marco Checcoli Thanks for your reply. Let me discuss this with the development team and let you know.
    • rg
      Thank you Naresh Patre
      • Naresh Patre
        Roberto In the example you shared, it can be noticed that Component2 is instanced as external as well as internal. See below image.
        Somehow, I was unable to create such instances at my end and would like to know how you were able to create internal and external instance of Component2. This will help to investigate this issue further.
    • mu
      Naresh Patre
      Hi Naresh,
      in the attached video you can see that in this case the icon that represents Internal or External component are “not true” (bom continues shows them as the same component). The separation between the two components icon happens when we make external sub-assembly “asm_01”.
      • Naresh Patre
        Marco Ugolotti Thanks for sharing the steps. I will pass it on to development team and will let you know their response.
    • rg
      Naresh Patre Hi
      You have some news?
      Regards
    • Naresh Patre
      Hello  Roberto
      I have submitted a defect for this issue. Below are the defect details for your reference. I will keep you updated on this defect as I hear about its progress.
      Defect Title: Problem while saving component in a sub-assembly
      Defect ID: DE189755
      Release: 2019 R1
    • rg
      Thanks for letting me know
Viewing 9 reply threads
