Preprocessing
Preprocessing
Replicate Symmetry with Nodal Displacement
    • Johanna_L
      Hi!
      Defining Symmetry Region with geometrical faces does not work for my body. Can I replicate planar symmetry with nodal displacements, e.g. set to 0 in the plane normal direction, or is the symmetry constraint something more? I am on ANSYS Workbench 2019 R2 if that matters.
      I'm still new to ANSYS and FEA. Thank you in advance,
      Johanna
    • 1shan
      You could replicate symmetry for solids by applying a frictionless support/ zero displacement normal to symmetry face. In case of surfaces/2d elements then in addition to fixing displacement along the symmetry plane normal you need to fix rotation along the 2 axes lying in the symmetry plane.
      Regards Ishan.
    • Johanna_L
      Thank you for your answer !
      Just to clarify, when I specifically can't use faces - can I do this by creating Named Selections of nodes and applying the displacement constrain in the normal direction on that group?
      My mesh is with tetrahedrons, so I don't need to lock the rotation then?
    • peteroznewman
      Solid elements such as tetrahedrons do not have rotational DOF on the nodes, only translations. For a symmetry BC, you only need to set the displacement normal to the plane to zero on solid elements.
Viewing 3 reply threads
