Discovery Import
Discovery Import
Reply to post doesn’t work
    • d.vleugels
      Devendra Badgujar
      I have replied twice to the previous question I asked titled: "Body and surface selection in scripting" which you replied to, however it seems that my replies are not logged when I hit the post reply. So this is an question/issue to be solved on its own ;)
      As reply to the other issue: I found a workaround that works (adding multiple groups together in a new groups solves the issue)
    • Devendra Badgujar
      Hi dvleugels
      Thanks for your reply and update on the above query.
      Apology for this issue with the forum, we have not seen this issue before but I will check what can be the reason for this.
      Regards.
