August 27, 2019 at 1:08 am
nevertrust
Subscriberi have done simulation on explicit dynamics. When i view report I found Solver Target “ Autodyn” on analysis table as shown in attach file. What does it mean? Do i really need to do simulation through Autodyn for post processing. Further information will be provided as per need.
waiting for your positive response.
thank you. -
August 27, 2019 at 1:42 am
Sandeep Medikonda
Ansys EmployeeANSYS Mechanical is using the AUTODYN solver to carry out the analysis, just like it uses the MAPDL solver.
You should still be able to Pre and Post process in Mechanical itself when using the Explicit Dynamics analysis system in WB.
August 29, 2019 at 1:35 pm
nevertrust
SubscriberThank you for your reply sir,
Does it mean the solution which i get from ansys mechanical is post processing result?
i want to attach image but it shows me problem to upload image.
Thank you.
2120
1349
1118
461
