Tagged: ansys-fluent-on-clusters, cluster, fluent, patch-with-tui, tui-command
January 11, 2023 at 7:04 pm
yutili
SubscriberI recently tried to do fluent calculations on cluster and after uploading the .cas file I need to add velocity output and animation using the command line. But I don't know how to achieve these actions, can I output the settings I made in fluent into command line?
I checked the command user manual, which only has a general tutorial like /solve/report-definitions/add , and I still can't output the data I want.
I tried the journal file before, but it seems to record all my mouse actions, so I can't get a complete command.
January 12, 2023 at 2:03 pm
Ansys EmployeeAdding graphical output into Fluent via the TUI is straightforward but setting the display surfaces, camera angle etc is much less so. If you set up the model on a local machine with graphics can you create all of the contours/scenes etc and then the animations there?
For graphics you want /display and /solve/execute-commands to then trigger the display. Note, if the model is run without graphics outputting images gets "interesting" as there isn't anything to display to.
2600
2088
1319
1108
459
