November 7, 2019 at 3:53 pm
almoussa
SubscriberHello, I am running simulations on HPC cluster using Fluent 2019 R2 in batch mode. My case file is setup to report output files and save them in the default directory. However when the simulation is done, I couldn't find the files in the folder where the case file is saved. I tried running the same case in interactive mode on the cluster and then the files were generated (which means there is nothing wrong with the case file). But I want to run my simulations in batch mode as its more efficient. Any solution for that?
November 7, 2019 at 4:42 pm
Ansys EmployeeSet the path explicitly: chances are the files were created "somewhere" on the system.
5290
3311
2469
