July 27, 2019 at 8:20 pm
CalebOU
SubscriberI am using ACP Pre and a mechanical model to import meshes into Explicit Dynamics, but since the geometries were created separately, the model in Explicit Dynamics does not have the bodies in the correct orientation to each other. Is there a way in ANSYS Mechanical to correct geometry position relative to each other, or where would be the correct place to perform that task?
July 28, 2019 at 1:30 am
August 2, 2019 at 1:12 am
CalebOU
SubscriberThank you!
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
