Discovery Import
Discovery Import
requested version is not supported by current subscription
    • omajo
      Hello, I have a customer with the following problems. (see attachment)   best regards
    • Brian Bueno
      olivier. majo
      Does the customer have a subscription that is valid past the release date of the version they're trying to install?
      For example, if the subscription ends on 1 January and they are trying to run a version of SpaceClaim released on 2 January that will not work.
      • omajo
        Brian Bueno Brian Bueno
        hello brian, i have just checked
        the acces of my client
        he has the subscriptions to acces  to 2 licenses
        spaceclaim   until the date of 06-2020
        my client : society : NCI
        mail adresse : david.favre@nci-electronique.fr
        or j.najar@wanadoo.fr
        It's an urgent request because it's blocked.
        thank you in advance
        best regards
      • Brian Bueno
        olivier. majo
        The subscription assigned to david.favre@nci-electronique.fr has a maintenance expiration date of 29 June 2019.
        The activation ID ends with "dd8".
        It's a perpetual license so the software will be accessible, but without renewing the TECS he will not be able to upgrade to any version released after the expiration date.
      • omajo
        Brian Bueno
        Hello Brian
        here is Mr. Favre's registration form attached. It dates from 07 June 2019, for a period of 1 year. We have placed an order with Bruno Chollat, for the period from 30 June 2019 to 29 June 2020. On these registration forms, there is no date to verify the period covered.
      • Brian Bueno
        olivier. majo
        I have removed the file attachments from your post, as those are publicly visible and contain the activation key.
        The license which is valid for the newer version is assigned to thomas.najar@nci-electronique.fr and has not been activated on any devices.
        The account administrator can unassign it and change it to another user if necessary.
      • omajo
        Brian Bueno
        hello brian,
        i'm sorry for the file
        thank you.
        I will transfert the informations to my client
        best regards
      • omajo
        olivier. majo
        hello brian,
        i have with my client the same problem
        see the attached files
        its administrator account
        is correct with the correct assignments
        and the right email addresses
      • omajo
        olivier. majo
        the licences folder is in fact the scan of the manage account
        can you see it ?
        there is 2 licences assigned .
        May I have to explain my client to redo all the process
        of assignation ?
        best regards
      • Brian Bueno
         olivier. majo
        Yes, I would recommend that they unassign the licenses and try again.  It looks like 2 Discovery Essentials licenses are assigned to David Favre.
      • Brian Bueno
        olivier. majo
        Please be aware that we have been experiencing a technical problem with the account portal at myaccount.ansys.com that has affected releasing activations. I'm not sure if this will also affect the assignment of licenses.
