March 19, 2022 at 7:16 pm
afshiin.a
SubscriberHello
I want to get a system with the following specifications.
processor: AMD RYZEN 9 3950x - 16 core, 32 thread, 64MB Cache
RAM : 32 GB DDR4
Question 1: Are these specifications suitable for Lumerical performance?
Question 2: Is AMD processor better for Lumerical simulation or Intel processor?
Question 3: Does having a graphics card affect computing speed and performance? If the answer is positive, Nvidia is better or AMD graphic card
March 22, 2022 at 2:17 amLito Yap
Ansys EmployeeSee this article on how hardware affects Lumerical (FDTD) simulations. The faster the Memory Bandwidth the better. For AMD RYZEN 9 3950, memory bandwidth: [memory speed in MHz]*[# memory channels]*[8 bytes]/1000 = 3200x2x8/1000 = 51.2 GB/s. See this post for details on how to obtain a simulation's optimum resource configuration on a computer.
- Error on Lumerical device
2688
2138
1351
1136
462
