September 27, 2017 at 11:19 am
admin
Ansys EmployeeHow to reset ANSYS SpaceClaim Direct Modeler?
October 17, 2017 at 6:06 am
admin
Ansys EmployeeTo reset ANSYS SpaceClaim Direct Modeler as default, 1. Close SpaceClaim 2. Go in the folder %appdata% and rename the folder SpaceClaim as SpaceClaim.old You could also try to clear the following keys in your registry: - HKEYCURRENTUSER > Software > SpaceClaim > LicenseReset > Reset - HKEYCURRENTUSER > Software > SpaceClaim > Primary > LicenseType
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5242
3281
2467
