Residual stresses
    • Evgenii_K
      Hi guys, I created a test problem in which I want to investigate the accumulation and distribution of residual stresses after bending a bar.
      The scheme is elementary - this cone beam with a concentrated load at the end:
    • peteroznewman
      You got valid results in the first model. You were unsuccessful doing the export-import. The second model has zero stress. Why are you exporting then importing?
    • Evgenii_K
      Hello peteroznewman
      I realized that I was doing wrong.
      Exporting stresses to a file:
      Connection Properties:
      peteroznewman, I don't understand what the problem is
