August 19, 2022 at 3:37 pm
mpalei
SubscriberHi,
I've been trying to generate BSDF's for various surfaces using the method detailed here:
https://optics.ansys.com/hc/en-us/articles/360042213854-Bidirectional-scattering-distribution-function-BSDF-
I just had a question about the resolution of the polar plots generated using the script given on the page above. Using my own surfaces I see the angular distribution polar plots that look much more coarse in resolution (attached below) than that of the page itself, and that the reflected and transmitted plots have different resolutions as well. I was wondering if there's something in particular that affects what the resolution of these plots ends up as? From what I can tell in the script in the BSDF analysis object it uses a variety of different functions to calculate the far field projections but it's not super clear to me what causes this disparity.
August 19, 2022 at 5:14 pm
Guilin Sun
Ansys EmployeeI guess you are suing periodicBC+plane wave and using gracting analysis? or using Gaussian+PML with farfiled3d?
When log scale is used for grating analysis, it is not the "coarse" issue but the grating orders. The more orders the rough surface can produce the smoother the result.
You may refer this post to get info regarding to the two different methods: https://forum.ansys.com/forums/topic/difference-between-gratingpolar-and-farfieldpolar-function/
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- How to calculate the cross-polarization efficiency and phase in FDTD
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2656
2120
1347
1118
461
