July 1, 2019 at 10:40 am
lampela
SubscriberHello everyone,
I have excel sheet with results of calculation for 30 geometry configuration of my simulation case. The problem is that i want to create response surface from that data, but i am able to upload from external file just input data. Is it possible to upload design point with both input and output parameters values?
Thank's in advance
July 1, 2019 at 3:04 pm
Ansys EmployeeIf the data is in Excel why don't you create a surface plot there? I used 3d Surfer for this about 20 years ago, so assume you can do it in Excel!
July 1, 2019 at 3:08 pm
lampela
SubscriberThat's right, but i would like to do optimization, using MOGA algorithm, and from my knowledge it's not implemented to excel..
July 1, 2019 at 6:29 pm
SubscriberDo you have access to matlab and its optimization toolbox?
July 1, 2019 at 7:34 pm
lampela
SubscriberUnfortunateli i don't have.
- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
3648
2534
1745
1226
578
