Tagged: frequency-response, function, response-spectrum, seismic, transfer, transient
December 3, 2022 at 5:21 pm
AR
SubscriberHello,
I need to obtain the seismic transfer function for a seismic event but I don't know how. Does anyone know how to do it?
In the image below you can see a graph that shows the entered spectrum (black line). The other lines are the behavior, that is, the response of some nodes of interest to the entered spectrum. However, I don't know what kind of analysis I can perform to get these values. Does anyone know how to do it?
December 3, 2022 at 5:46 pm
SubscriberIn Workbench, create a Modal analysis and use Fixed Supports for the connection of the structure to ground.
Then drag a Response Spectrum analysis and drop it on the Solution cell of the Modal analysis. You can then use the Input Spectrum in this analysis as a Base Excitation.
Take some courses to learn Modal Analysis and other Dynamic Analyses such as Response Spectrum.
https://courses.ansys.com/index.php/courses/modal-analysis-in-ansys-mechanical/
December 3, 2022 at 6:02 pm
AR
SubscriberHello Peter,
I have already done a modal analysis together with a response spectrum. However, with that I can't get acceleration results for each frequency.
I have thought about performing a harmonic analysis but with it I cannot insert a seismic spectrum.
Do you know any other way to do it to get the graph or the values to perform the graph from the previous post?
Regards
December 3, 2022 at 8:29 pm
- The topic ‘Response spectrum and seismic transfer function’ is closed to new replies.
2138
1351
1136
462
