restart analysis
    • m.caragiuli
      Since I've seen the option "restart analysis" in Analysis Settings which allows to save the simulation while is running at selected substep or step. How is then possible to recover the solution at the last substep before divergence or interruption in order to restart the analysis? Should I simply read the rst file and then select the last substep and run again? If yes, since there are lots of .rst files which one should I select?
      Thanks!
    • peteroznewman
      Here is a video that includes instruction on restart.
    • m.caragiuli
      thank you!!
