April 22, 2023 at 3:45 pm
yutili
SubscriberHi,
I am doing a 2 phase bubble injection in water simulation, and its runs in the cluster. but when the calculation interrupt and I want to restart the calculation at the stopped timestep, I load the cas. and data. file with /file/read-case-data /path/to/case/file.cas /path/to/data/file.dat the boundary condition and previous data like inject velocity disappeared. And those situations only happened in cluster, in Windows fluent software it run correctly. Does anyone know why it happens?
Thanks in previously!
April 24, 2023 at 8:46 am
Ansys EmployeeAssuming you're running standalone and haven't got any UDFs set all boundary data is stored in the case file. Which version are you using, and please confirm if you're saving .cas.gz or .cas.h5 formats.
5162
3251
2443
