March 2, 2022 at 1:10 am
tul17693
SubscriberI am trying to restart a simulation using runrsf. The keyword deck has an *INTERFACE_LINKING_NODESET keyword in it. I noticed that when I run it on MPP, it reads the runrsf file but gives error termination on the next iteration. However, when I run this on SMP, it works. Is it possible to restart a simulation with *INTERFACE_LINKING_NODESET keyword on MPP? Or is this not yet supported on LS Dyna MPP?
March 18, 2022 at 6:32 amUshnish Basu
Ansys EmployeePlease make sure to check using a recent release version of MPP. Please also check if you can do a simple or small-deck restart using d3dump rather than runrsf.
If it's still an issue, please post details of the MPP version you have tried, the command you use to run the restart, and the specific error you are getting.
Trending discussions- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
2524
2066
1279
1096
457
