February 4, 2023 at 12:18 pm
mailoan
SubscriberHi everyone,
How to restrain 3 motions of surge, sway, and yaw in ansys AQWA?
My problem is to calculate RAO of heave and pitch only of the ship. As I know, AQWA has 2 options one is free all motions and another is fix all motions. There is no option for free only 1, 2 or 3 motions.
I would like to receive your response.
Thank you in advance.
February 6, 2023 at 2:48 pm
Mike Pettit
Ansys EmployeeHello,
It is not possible to fix individual freedoms, but you can constrain the structure motions in surge, sway and yaw by defining an Additional Hydrostatic Stiffness matrix for the structure, and setting the X-X, Y-Y and RZ-RZ stiffness terms to be very large. Once you have defined your additional stiffness and run the diffraction calculation, you should check that the natural frequencies in X, Y and RZ are at least an order of magnitude greater than the natural frequencies in the unconstrained freedoms; you can find these values in the diffraction analysis LIS file, by searching for the string 'N A T U R A L F R E Q U E N C I E S / P E R I O D S'.
I hope this helps.
Mike
February 10, 2023 at 4:32 am
mailoan
SubscriberThank you so much for your response.
Your answer helped me a lot. I understood it.
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5242
3297
2467
