Restrict deformation to a limit
    • Chinmay
      Hii,
      As you can see in the image, my deformation is going beyond the metal housing. I want to restrict it without giving deflection in structural analysis. I tried giving displacement in static structural but it creates a bow shape of the tongue. Please help. Thanks.
    • Aniket
      please review the guidelines before posting a question. You can find them in my signature for easy access. Also Ansys staff can not access the attachments on the community so please use the ‘Insert Image’ option to share your images. Please refrain from using the ‘Attach’ option as much as possible.
      -Aniket
    • Chinmay
      Thank you for your response, I have read all the guidelines on student community and edited my post accordingly.
    • Aniket
      have you defined a frictional contact at the following location highlighted in red and green?
      -Aniket
    • Chinmay
      No, I haven't. I will go with edge (red) and area (green) contact and I think that will do it. Thanks a lot. Will let you know soon.
    • Aniket
      anticipating contact will be face to face due to deformation instead of edge to face, Go for face to face contact instead.
    • Chinmay
      I can't add Edge and Face contact at a time ? I anticipated that the edge will rub first and then the area might come in contact (not sure though, will have to check). I have around "8 faces and 2 Edges" on contact and "8 face" contacts on target. I am not able to select face and edge simultaneously. Thanks.
    • Chinmay
       Hi, I tried the method you suggested. It restricted deflection beyond the metal surface but unfortunately it started with that area in contact. I need the tongue to deflect during insertion but the tongue shouldn't cross boundaries. My apologies, I should have mentioned this at the start of this discussion. I found following result.
      The yellow (bow shape) marked is undesirable, Green and Red faces were taken to be in contact. I need to take edge contact for green and face contact for red but it seems it will give similar result. Should I add another manual contact along with previous ones ?
      Thanks. Any suggestion is most welcome.
    • Aniket
      Sorry what's the exact issue here? It does seem to behave as expected here to me! Am I missing something?
      -Aniket
    • Chinmay
      Yes Sorry, my bad. It's behaving at it should the only amendment was to provide edge contact to face contact. Thanks for your solution. You're awesome. Much obliged.
Viewing 9 reply threads
