Restrict rigid solid motions in Ansys Workbench
    • manmorcan
      Hi everybody,nI'm simulating a kayak. I introduced the forces but I need at least one support.nnHow could I avoid this rigid solid motions so as I could simulate the kayak?.Thanks in advancen
    • Erik Kostson
      HinOne way is to use inertia relief option in mechanical - under analysis settings.nthank younnErikn
    • manmorcan
      Thank you a lot ekostsonnnI turned on Inertia relief option and I got this:nnnnHow could I solve it?.Thank you a lot!n
    • manmorcan
      I activated both Inertia relief and weak springs and it worked.nnThanks!!n
Viewing 3 reply threads
