August 17, 2023 at 7:12 pm
August 18, 2023 at 1:25 pm
Ashish Kumar
Forum ModeratorHi,
Use D command.
Ashish Kumar
August 18, 2023 at 1:30 pm
Massochy dos santos Ventura
SubscriberI used this command and the following information appears but without a solution
D ,All,UX,UZ,ROTX,ROTY,ROTZ,0,
August 18, 2023 at 1:32 pm
SubscriberDo you have an example of a D command to restrict degree of freedom on all nodes
August 18, 2023 at 1:55 pm
Ashish Kumar
Forum Moderator -
August 18, 2023 at 2:45 pm
SubscriberEstou trabalhando com 25 nós e usei este código
CSYS, 1
D, TODOS, UX
D, TODOS, UZ
D, TODOS, ROTX
D, TODOS, ROTY
D, TODOS, ROTZ
NSEL, TODOS
ACABARe eu tinha uma matriz 25 * 25 por ser o número de nós vezes o grau de liberdade, mas eu tenho frequências naturais iguais a zero em todos os modos. Eu gostaria de saber se este resultado está correto
August 19, 2023 at 8:48 pm
Mike Rife
Ansys EmployeeHi Massochy
This command is not quite correct: D ,All,UX,UZ,ROTX,ROTY,ROTZ,0,
Please see the MAPDL Command Help entry on the D command for the description of the commands fields. But most likely you wanted: d,all,ux,0,,,,uz,rotx,roty,rotz
Mike
August 19, 2023 at 9:01 pm
SubscriberI wonder if with these commands I can restrict the degrees of freedoms??
August 19, 2023 at 9:41 pm
Mike Rife
Ansys EmployeeWhat do you mean by restrict?
August 19, 2023 at 9:47 pm
SubscriberI'm doing a modal analysis on a free-free steel plate in order to extract stiffness matrix, mass matrix and the vectors corresponding to the vibration modes for each natural frequency. in order to reduce the values of the matrices so I intend to restrict some degrees of freedom all nodes since the matrix is formed by the multiplication between numbers of nodes and the degrees of freedom (in this case they are 6)..
4440
2953
1427
1322
