June 26, 2020 at 2:21 pm
Yukieperamesti
SubscriberHello,
I have a problem with my result in ansys fluent. I want to show the contour of static pressure.
The contour consist of different colours, but the legend of contour is the same number.
Is there tool for change and make it in the same colour if the result is the same number?
Thank you so much, please let me know if there's the tool for fix it. -
June 26, 2020 at 3:14 pm
RK
Ansys EmployeeHello,
If you see different colors, then there are probably different values across the domain. To be sure of it, In the contours window, click on "Colormap Options", select "Type" as float and and increase the value of precision.
June 26, 2020 at 3:58 pm
Yukieperamesti
SubscriberThank you so much Sir for the answer. It works in my result
3930
2649
1861
1272
610
