February 10, 2022 at 9:04 am
yhamurisci
SubscriberHello,
Is there any practical way to combine solutions of two discrete mechanical systems in Workbench? It is OK to combine solutions of connected models that share same FE-model and have different loads, BCs "Solution Combination", but this case is a little different.
Two systems consist of identical FEA model except different symmetry definition so they should have been discrete.
Thanks in advance, regards.
February 10, 2022 at 5:43 pmAshish Khemka
Forum Moderator
Solution combination is fine when the two analyses are linear in nature. With different symmetry definitions, I am not sure if combining the results might help you. If you share details of your setup then it might be easy to comment if you can do a solution combination. Maybe you can have the same model but define a boundary condition to capture the effect of symmetry (again depends on which symmetry you are using).
Regards Ashish Khemka
- A solver pivot warning or error has been detected
8798
4658
3151
1680
1470
