Result error
    • uddomchheng
      Hi.
      My model is RC column connected to RC beam. Boundary condition is applied at the base of beam ux=uy=uz=0, and cycling lateral displacement is applied at the top of column. Moreover, stress is applied on the top of column surface 4MPa. The statically applied step is from 0s-1s stress applied and from 1s-6s lateral displacement applied. After running, messages show. The unit used is tonne, mm, N.
    • John Doyle
      It doesn't look like you are constraining rotation.n
    • uddomchheng
      Thanks a lot sir. I'll check soon.n
    • uddomchheng
      It doesn't look like you are constraining rotation.https://forum.ansys.com/discussion/comment/104720#Comment_104720
      Dear sir, After I changed the constrain, the message shows. An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes.
Viewing 3 reply threads
