Discovery Import
Discovery Import
Resulting moment, AIM, Fluids
    • info
      Is there any 'built-in' or scripting solution to etract the resulting moment (taken to e.g. an axis of a reference frame, similar to structural) from surface pressures exerted on an immersed (bluff body)?
      steelxpert
    • Gaurav Sharma
      steelxpert
      I don't think this is possible with a pure fluid study. While extracting forces is possible, extracting moment need information of arm length which is not present in a fluid study and hence moments doesn't seem to be a possible output in a fluid study.
       However, the same can easily e extracted by performing a FSI study. The fixity provided in the structural side completes the information required for calculating moment, and can be used to extract moment reactions using calculated values.
      I have performed a sample FSI study that is attached herewith and can be used as a reference. hope you find it useful.
      Thanks & Regards,
      Gaurav
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • info
      Gaurav_ANSYS ,
      Thank you for your reply, it makes sense.
      I ran into another problem while trying to evaluate the results in the supplied sample file - see attached error message.
      Csaba
      • Gaurav Sharma
        steelxpert
        This is surprising as the archived file I shared can be accessed at my end without any issues.
        The best way to access an archived model is by going to file >> Open >>browse for the wbpz file and click on "open". The popup will now prompt the user to save this model as *.wbpj. Once it is saved, you are all set to go. I hope you are following this approach?
        Also, what version of Discovery AIM are you using?
        Generally, such system specific issues with AIM can be resolved by:
        1. Clear the contents of temp folder (type %temp% in windows Taskbar to access temp folder)
        2. Close all the open Discovery Applications and go to the following appdata folder (C:Users****AppDataRoamingAnsys) and rename the folder v194 to v194.old)
        Open a new session of AIM and open the archived file. Solve the model to see if the problem is still there.
        Thanks & Regards,
        Gaurav
    • info
      Gaurav_ANSYS
      Thank you for the response.
      I am an experienced ANSYS Workbench user, do always keep doing this way.
      What do you mean to go to the folder specified at 2.?.. what to do then, once located?
      Csaba
      • Gaurav Sharma
        steelxpert
        You just need to rename the folder v194 to v194.old, as I have done with the folder named v193 (corresponding to version 2019R1) here:
        Now when you will open a new session of AIM, a fresh folder named v194 will automatically get created.
        I hope this helps.
        Thanks & Regards,
        Gaurav
    • info
      Gaurav_ANSYS
      Sorry, I was distrait when reading your previous instructions.
      Thank you for your help.
      Csaba
Viewing 4 reply threads
