May 25, 2023 at 9:38 am
ranko simic
Subscriberin workbench i've connect solution from Fuent node with results in Results node. When i start edit results I've got error with message 'The application has encountered an unexpected problem and will now terminate ' ... have you got any idea what is problem
thanks
May 25, 2023 at 2:30 pm
Federico Alzamora Previtali
SubscriberIs your Solution complete with the green check mark? When you right click and Edit... what is the application that Workbench tries to run?
May 26, 2023 at 8:05 am
ranko simic
Subscriber>Is your Solution complete with the green check mark?
yes
when i right click on results end left click on on Edit in popup window, workbench try to start cfd-post
May 29, 2023 at 1:09 pm
SubscriberHello Ranko,
what version of Workbench are you using? Is this a Student license? What is the size of the mesh and the format of the output files for CFD-Post?
You could also try using Ensight for your post-processing.
5268
3299
2469
