November 20, 2020 at 4:15 am
helen.durand
SubscriberHello!
If I stop a transient structural simulation using the 'Interrupt Solution' (as in the figure below), are the results correct (up to the time step where I interrupted the simulation)?
I tested it and it appears that I get the same results as I would if I let the simulation run completely, but I get a message about the solution not being converged when I look at the results. Are there situations where the results would not match?
November 20, 2020 at 7:24 pmGary Stofan
Ansys EmployeeThe result could indeed be correct, but there is no way to be sure. nIt seems you may be running the transient much longer than it needs to be anyway. I would recommend adjusting your analysis settings. nViewing 1 reply thread- You must be logged in to reply to this topic.
- A solver pivot warning or error has been detected
8700
4658
3151
1672
1446
