Results for a selected surface
    • chiaram
      Hi everyone!
      I would like to select a circle on a surface and visualize all the nodes results in that surface. How can I do it?
      A path is not ok because it is only the circumference. I tried a surface but I cannot select a small circle of given radius. Is it possible?
      I also tried to design a surface in the Design Claim but I have problem relating contacts between the solid and the circle surface (mixed dimension analysis 2D/3D).
      If you could help me, it would be highly appreciated!
    • Aniket
      can you create a circular imprint on the body directly either in SpaceClaim or in DesignModeler?
      -Aniket
