Resuming solution
    • Devaiah
       Is there a way by which I can restart the solution from the previous converged sub time step? I have seen threads where it asks for restart point in Restart controls tab. However, I don't see the same in the 2019 version.
      Attached is the analysis settings options that are available to me.
      Thanks!
    • Aniket
      Ansys staff can not download images on the student portal, so if you want to reach a larger audience to get answers from, please insert the images inline.
      -Aniket
    • Devaiah
      Re-post with image inline:-
      Below are the analysis settings options that are available to me.
      Thanks!
    • Wenlong
      The restarting point can be defined in the "Restart Controls" of the image you shared. You can change the "substep" and "load step" to define how frequently it write restart file.
      More detailed information can be found here: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_Restart_Controls.html
      Wenlong
      Useful Links
Viewing 3 reply threads
