Retrieve Residual Plot File
    • Kobee
      Hello Ansys Family,
      How do I retrieve and plot the residual of a simulation in excel?
      I wanna compare the residuals of two plots to analyze the convergence. Thank you for suggestion
    • Kalyan Goparaju
      You can use the TUI command below to write residuals to a txt file. Issue this command before running the simulation.
      /plot/residuals-set/plot-to-file "Filename.txt"
      Thanks,
      Kalyan
