Retrieving Surface Reports in CFD Post
    • amr92
      I have a simulation where I didn't create (forgot) a report file in FLUENT previous to calculation. However, I do have contours generated from the animation reports. Is it possible to retrieve area-weighted values from these?
      Not without image processing software and an excessive amount of effort. You'll either need to manually extract the data from any saved (data) files or re-run. I've just done much the same after recovering files from a server node failure, so am seeing what the trend is to decide if I need to re-run.
