June 1, 2023 at 12:17 pm
Sahith Kumar Dandanayakula
SubscriberFor example i have created a path using two points in Mechanical and i want to create are array with columns like the lenght of the path and x,y,z coordinates. These array values can be used for postprocessing the stresses and defromations along the path and at path coordinates. I have done this manually by exporting to text data. But I am attempting to automate my model. So, what commands should be used to get the path coordinates into an array in WB with APDL commands? Please see figure below for your reference how the path data looks like when exported to text file.
Where S is the lenght of the path or in other words distance between to points on the path.
June 2, 2023 at 8:23 am
Claudio Pedrazzi
SubscriberHave a look at the Help for the *GET command, specifically the
Table 169: *GET Postprocessing Items, Entity = PATH
I have never tried this, but obviously it is possibile to loop through all the points of the PATH and extract coordinate information. I would write this out to a .txt file, with APDL commands. You ask for an ARRAY in WB, I don't know the answer to this part of the question.
Hope this helps
Best regards
Claudio
4504
2971
1449
1322
