Retrofitting through Jacketing
    • Mark Frederick Manalac
      Is there a proper way in applying steel plate jacketings? In the image below we made it just by making solid components from pulling, then added the bolts as solid components as well. Thanks in advance.
    • Saumadeep
      Hi Mark,
      I think the way you mentioned is the proper way to create a geometry of steel jacket. For modeling and analysis of Bolts, you can check out the following Ansys free Learning Track: Pre-loaded Bolted Connections - ANSYS Innovation Courses
      Saumadeep Choudhury
