REV Material Designer
    • barisoa
      Hi everyone.
      I will be grateful if you could help me or share tutorials or guides on composite MD designer (REV from a geometry).
      Best regards
    • Wenlong
    • barisoa
      Hi, Wenlong,
      Thanks a lot.
    • barisoa
       Hi everyone,
      How can I extract the engineering constants (Ei Gij nu_ij and rho) from the results of a composite REV simulation in Statistics analysis? (without using material designer).
      Kind regards
    • Wenlong
      You can apply such a BC to your block, do a tensile test in each direction, plot the stress vs. strain curve and get the E for that direction, then use the cross-section reduction area to find the nu.
      For the shear modulus G, I am not so sure, maybe others can contribute.
      Wenlong
Viewing 4 reply threads
