reversed flow at mass flow inlet species transport
    • imungan
      Hello. I am simulating ethylene fueled combustion case. I did aerodynamics analysis. In second analysis fuel injected into domain. While running i am facing reversed flow and temperature problem. However it did not crash. When iterations are finished, i navigate the result. The residual is not reasonable. What should i do? Thnak you in advanced.
      You can see the screenshot of required info below.
    • DrAmine
      Well the global scaled residuals you are sharing are telling me that the case did not converge and the results should not be trusted.
      Are the inputs into you p-farfield correct? Where is it located?
    • imungan
      I dont think inputs are incorrect. They are corresponding to Total pressure 164,5 kPa and total temp 2204 K with Mach 4,5
    • DrAmine
      I did not wrote they are incorrect: I wrote please check (espcially if the proper isentropic exponent is used there).
      Are you using the pressure based solver?
    • imungan
      density based solver
    • DrAmine
      Makes sense. Can you list the model settings you are using. Thanks.
    • imungan
      Operating Pressure = 0
      Density Based Solver
      k-w sst - compressibility effect
      species transport - volumetric - finite rate / no tci - thermal diffusion - ethylene/air
      ethylene/air --> density: ideal gas - viscosity: ideal gas mixing law - mass diffusivity: kinetic theory - thermal diffusion: kinetic theory
      air ---> density: ideal gas - viscosity: sutherland
      inlet (pressure far field) --> P=5568,4 Pa - 4,5 Mach -T=436,4 K - Intensity and hydraulic = 5/0,0441 m - O2:0,232 h20:0,032
      fuel (mass flow inlet) --> 5,8e-4 kg/s - 100666,8 Pa - total temp:300 K - intensity - hydraulic = 5/7,5e-4 m - c2h4=1
      outlet --> intensity and hydraulic = 5 / 0,0675 m (rest is default)
      hybrid initialization
      fmg initialization
      high speed numerics enabled
    • imungan
      Roe Scheme
      Implicit - Steady State
      Gradient: Least squares cell based
      flow: 2nd order
      under-relaxations are default
Viewing 7 reply threads
