March 16, 2021 at 10:04 pm
shehab Gamrah
SubscriberI have a vibrating inner sphere 14 cm diameter (blue) that reaches a maximum velocity of 5 m/s and an outer sphere (grey) of 16 cm diameter. The gap between the spheres is 1 cm containing a fluid of density 1000.567 kg/m3 and viscosity 0.0009 kg/m. s. I used the viscous laminar model and the solution converged, however I was wondering should I use a turbulence model, and also how can I find Reynolds number for this case. Also if viscous laminar model worked properly, does it mean the flow is laminar.
March 16, 2021 at 10:18 pmYasserSelima
SubscriberI think using the gab between the two cylinders as a characteristic length would be reasonable. nIf the results you got is similar or close to experimental data, the model you used is valid. If you don't have experimental data and you don't know if the flow is turbulent or laminar, use a transition model like k-omega ... but in this case you will need to refine the boundary layer nMarch 18, 2021 at 3:02 pmshehab Gamrah
SubscriberThanks for your help. I have a question regarding y+ value. when I calculate y+ value do I use the value of the sphere's vibrating velocity, or an approximate value of the fluid's maximum velocity as the fluid's velocity would be much higher than the inner sphere as a result of the vibration nMarch 18, 2021 at 4:18 pmYasserSelima
SubscriberI don't think the fluid velocity would be much higher than the sphere. nMarch 18, 2021 at 7:05 pmshehab Gamrah
SubscriberI miswrote a number in the first comment. The sphere's maximum velocity is 1.5m/s, however the fluid's velocity reaches a maximum value in the range of 5-5.3 m/s.nMarch 18, 2021 at 7:12 pmDrAmine
Ansys EmployeeYou might assume the fluid to be weak compressible to avoid any velocity overshoot.nMarch 18, 2021 at 7:13 pmDrAmine
Ansys EmployeeHow are u modeling the vibration or motion of inner sphere?nMarch 19, 2021 at 12:42 amshehab Gamrah
SubscriberThrough a udf code of inner sphere and solid deforming. And turbulence model kepsilon realizable. I've done mesh convergence and the residuals converge and the results don't vary as mesh is reduced.nMarch 19, 2021 at 3:34 pmRob
Ansys EmployeeThen you've probably got as good an answer as you can, assuming the various settings (materials, bc's etc) are correct. nViewing 8 reply threads- You must be logged in to reply to this topic.
2656
2120
1347
1118
461
