July 22, 2019 at 4:40 am
Abhi1311
SubscriberGreetings! I have a few questions so please take a look at them,
1. I am simulating gas flow inside a closed chamber with one inlet and one outlet. Earlier we were using Turbulence model but after i calculated reynolds number it came out as laminar flow. So by changing model am i going in the right direction? How important is it?
2. Also I'm planning to change the gas temperature too. As dynamic viscosity is dependent on temperature, it may change due to change in temperature which may in turn change the reynolds number so my second question is that will the flow will turn turbulent of constant flow rate after certain increase of gas temperature?
July 22, 2019 at 10:55 am
Ansys EmployeeVery roughly, running a turbulence model on laminar flow will make fluid jets etc more diffusive. Running laminar on a turbulent flow tends to either pick up transients in the flow or have poor convergence.
If you alter the physical properties you could trigger a change to turbulent flow at a constant flow, but that's for you to work out. Remember, if the temperature changes a lot you may also want to alter density.
2524
2066
1279
1096
457
