October 22, 2018 at 7:02 pm
abbas
Subscriber -
October 22, 2018 at 7:20 pm
DrAmine
Ansys EmployeeThe Component Name is a required field, because .rgp files can hold data for more than one pure substance. Just give the one of Gas component if it does contain explicitly the $$SAT_TABLE and the related the single and double values entities and give it a try.
October 23, 2018 at 2:14 pm
abbas
SubscriberSo,
Based on what you said, I can just give one of the tables (either liquid or vapor) for Saturation Properties even though these two tables are defined for liquid and vapor phase separately?
Best regards,
Abbas
October 23, 2018 at 2:59 pm
DrAmine
Ansys EmployeeYes. Use the one RGP which contains the SAT_TABLE. I generally use only one RGP which contains everything (might contain double entries but you might ignore it at first).
2616
2098
1323
1108
461
