December 6, 2019 at 10:31 am
conni
SubscriberHi,
The 2019R3 Version of Fluent allows for the use of rgp-tables like in Refprop (beta feature).
To generate such tables it is recommended in the Beta Features Manual to use the System Coupling command console (which is launched under Windows by running the systemcoupling.bat batch file).
When executing the Code as listed in the Manual (but for butane instead of h2o), it seems to work, , then outputting:
"Writing RGP File...
Filename is BUTANE-med.rgp
Writing Header Information...
Writing BUTANEL 2D tables...
Writing BUTANEL Saturation tables...
Writing BUTANEV 2D tables...
Writing BUTANEV Saturation tables...
This is the last Output, it seems like the Programme then stops. However, I cannot find the file 'BUTANE-med.rgp' anywhere on the Computer... Does anyone know where the rgp file would be saved by Default, or if there could be a Problem with proceeding in that way so that there is another reason that i do not obtain a rgp-file?
Thanks in Advance! -
December 6, 2019 at 5:56 pm
DrAmine
Ansys EmployeeIn the working directory if not else mentioned in the docu. Issue a search in file explorer. -
December 7, 2019 at 8:10 am
conni
SubscriberThank you for the answer. I tried a file Explorer search, but it did not find any file… Could it be that there is a Problem that no file is created? Should, if the process is successful, another message turn up in the command prompt after "Writing BUTANEV Saturation tables… " ?
March 9, 2020 at 6:39 am
harrivin
Dear conni,
Did you manage to locate where the RGP file is located?
March 9, 2020 at 10:27 am
DrAmine
Ansys EmployeeIt would write the files in the directory where you execute the command (tested today).
November 25, 2020 at 1:16 pm
Tombock
SubscriberI have the same error, I don't find the rgp files after the end of the scriptn -
November 25, 2020 at 1:46 pm
DrAmine
Ansys EmployeeIt would write the files in the directory where you execute the command (tested today). nn -
November 25, 2020 at 2:07 pm
Tombock
SubscriberThanks DrAmine for the fast answer!nI have already check all the folders and the current directory, but I don't find the .rgp files. It's like the script doesn't save them.nDo you use this script 6.1. Real Gas Property (RGP) Table Files (ansys.com) ?n
5268
3299
2469
