May 20, 2023 at 10:42 pm
Suruchi bala
SubscriberHi,
Kindly update Spontaneous Four-wave Mixing (SWFM) Microring Resonator Photon Source – Ansys Optics this example, as rib_waveguide.lms file is missing in the zip file and also check if out of effective mode and mode area script, which one has to run for step4.
May 23, 2023 at 4:38 pm
Amrita Pati
Ansys EmployeeHi Suruchi,
Thank you for bringing this to our attention. We will add the file.
Amrita
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5340
3325
2471
