Rigid body motion in static structural analysis
    • Frederik Zemlin
      I'm having trouble eliminating rigid body motion in my analysis. The solver fails always at 17% progress. The model is of a quarter symmetric BGA where the PCB has a fixed support and the cut faces have frictionless supports assigned. The load is a thermal condition applied to all bodies. All contacts are bonded, except for three rough ones with the coating on top. Formulation for the bonded contacts is set to augmented lagrange and the stiffness is updated every iteration. Running the contact tool reports no open contacts, all are closed and look normal. I have weak springs enabled.
      The solver reports the following error:
      *** WARNING ***                         CP =    3018.578   TIME= 19:39:20
       Material number 2519 (used by element 2005418) should normally have at
       least one MP or one TB type command associated with it.  Output of
       energy by material may not be available.
       *** NOTE ***                            CP =    3018.594   TIME= 19:39:20
       The step data was checked and warning messages were found.
        Please review output or errors file (
       E:\BGA_model\_ProjectScratch\Scr00BE\file0.err ) for these warning
       messages.
       This nonlinear analysis defaults to using the full Newton-Raphson
       solution procedure.  This can be modified using the NROPT command.
      *** ERROR ***                           CP =    3152.953   TIME= 19:41:34
       The value of UZ at node 957648 is 1.862045956E+11.  It is greater than
       the current limit of 1.E+09 (which can be reset on the NCNV command).
       This generally indicates rigid body motion as a result of an
       unconstrained model.  Verify that your model is properly constrained.
       *** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***
       If one or more parts of the model are held together only by contact
       verify that the contact surfaces are closed.  You can check contact
       status in the SOLUTION module for the converged solutions using
       CNCHECK.
       *** WARNING ***                         CP =    3152.953   TIME= 19:41:34
       The unconverged solution (identified as time 1800 substep 999999) is
       output for analysis debug purposes.  Results should not be used for
       any other purpose.
      Thanks in advance.
      Frederik
    • Ashish Khemka
      Hi Frederik,
      The error message indicates rigid body motion. You can create a named selection for node number 957648 and check which body is unconstrained.
      Ashish Khemka
    • Frederik Zemlin
      Hi Ashish,
      Thanks for the response. The body in question should be fully constrained as it has bonded contacts to adjacent bodies. I have tried adding an edge blend as the node sits on a corner but it didn't help.
      best regards,
      Frederik
    • Ashish Khemka
      Hi Frederik,
      Try running a quick modal analysis to see if you find any rigid body modes.
      Ashish Khemka
    • Frederik Zemlin
      Hi Ashish,
      the modal analysis has no free body modes. I think I found the cause for the rigid body motion, a material had a wrong very large CTE assigned. But get an error now that the solution doesnt converge at time step 1250.
      best regards,
      Frederik
    • Ashish Khemka
      Hi Frederik,
      Can you please share the snapshot of the solver output?
      Ashish Khemka
    • Frederik Zemlin
      Problem has been solved. Had to set the normal stiffness to 0.01 and solver to direct.
Viewing 6 reply threads
