Rigid-flex PCB bending EM analysis workflow
    • elie.perez
      Hi there,
      I am highly interested in doing EM analysis of Rigid Flex PCB.
      I have defined the bending lines in Altium designer.
      Is there a simple workflow with Ansys hfss to import all pcb parameter including bending lines ?
      In page 4/10 of this white paper :https://resources.pcb.cadence.com/clarity/fast-and-simple-rigid-flex-pcb-bending-em-analysis-using-clarity-3d-solver-2
      they explain a simple workflow with .brd files from allegro and clarity3D solver.
      Is there something similar in Ansys ?
      I can export .brd and . Idf from Altium but I am not successful with the importation in Ansys.
      I can  export into the ansys edb format from altium but I don't see any bending lines in HFSS 3D layout and I don't know how to do that.
      I am open to any suggestions.
      Thanks,
    • Praneeth
      Hi Elie,
      HFSS 3D layout does support flexible PCB feature starting with 2022 R2 release. To know more about this feature please visit the webinar - Ansys 2022 R2: What's New in Ansys HFSS | Ansys.
      Best regards,
      Praneeth, Ansys.
    • elie.perez
      Thank you for your help. I will watch the webinar.
      May I ask you if there is a pdf document that explains this feature ?
      Thanks,
      Best regards,
      Elie PEREZ
    • Praneeth
      Hi Elie,
      Here is the link to see more about the flexible feature - Whats New 2022 R2
      More information will be available along with the 2022 R2 release.
      Best regards,
      Praneeth, Ansys.
    • elie.perez
      Hi Praneeth,
      Thanks for the link. This new release looks great.
      Best regards,
      Elie PEREZ
Viewing 4 reply threads
