June 19, 2020 at 2:40 pm
LEMOSLD
SubscriberHi! Anyone know if fluent has a Macro for rms temperature? I am modeling turbulent combustion, in steady steate, using PDF model for generate the fluctuations. The rms temperature is available as a result, but I want to use the information in one UDF. I did not find this on the manual.
Thank you!
June 19, 2020 at 4:25 pm
Ansys EmployeeHave a look in the Fluent UDF Manual, you want the section on Time-Sampled Data.
June 19, 2020 at 4:54 pm
LEMOSLD
SubscriberThank you for answer. Yes, but my case is a steady state simulation. The PDF model provide the rms temperature, is a result, so I thought that I could use this information.
3670
2552
1751
1226
584
