.Rnn files not found error
    • hnorthrup
      I am running a 2-way FSI using the System Coupling 2021 R1 GUI. The simulation runs fine but sometimes the simulation stops partway through and I need to restart it. When I go to restart the simulation I get the following error "During the multiframe restart process, the .RDB file was found but the .Rnnn files were not found. Both files are required to perform the multiframe restart process." Below is a screenshot of some of the files that were generated. Aren't the "file0.r001" etc files the .rnnn files? Can someone please advise me how to proceed so that I can restart my simulations? Thanks!
    • Ashish Khemka
      Are you running the analysis on a cluster or cloud? The reason for the error during the analysis is that some files like file.rdb *.r001 etc were not stored/downloaded by default. These files should be stored/ downloaded for further analysis.
      Regards Ashish Khemka
    • hnorthrup
      Hi I am not running it on a cluster or cloud.
      Thanks!
      Hannah
    • Ashish Khemka
      Hi Hannah
      Did you make any changes to the model after solving the model? Can you try resolving?
    • hnorthrup
      I updated Ansys to the latest version and it is working now. Thanks for your help!
Viewing 4 reply threads
