TAGGED: ansys-mechanical, mechanical, structural-mechanics, structure, transient
January 25, 2021 at 12:31 am
Leonacha
SubscriberHi,
I am trying to import the pressure to carry out the analysis, but one of the fields that is magnitude (Pa) is empty, in the same way I cannot proceed with the analysis without filling in this field.
January 29, 2021 at 12:57 pmAshish Khemka
Ansys EmployeennFrom the warning message, it looks that the upstream analysis does not have any relevant data. If you have the data of pressure with locations (x,y and z) then you can use the External Data module to import and apply the pressure data.nnnRegards,nAshish KhemkaViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
5332
3311
2471
