Rod hitting the metal plate with velocity of 1560m/s
    • tanaji08
      Currently I'm doing a project on Simulation of rod hitting a metal plate using explicit dynamics, but I'm facing a problem regarding erosion of rod. My problem is that while simulation Erosion of rod is not  happening, so what changes I should do so as to get the erosion of the rod?
      Rod material is Tungsten alloy &
      Metal plate is of RHA (Rolled homogeneous armour).
      Please help me.
      Thanks in advance.
    • Raef.Kobeissi
      I thought erosion would take place on small scale, hence the mesh would have to be very high resolution. Can you share some pictures of the results you're getting?
      Regards
