November 23, 2017 at 7:12 pm
Zizi96
SubscriberHi
I'm trying to model a composite monocoque as part of my final year university project. In order to model the composite laminates I need to split my model into 2 sections so I can define separate rosette directions for the left and right side of the model to ensure the laminate can be built inwards on both sides of the model.
However when i attempt to split the model into 2 sections in Design modeler I exceed the geometry limits (model has 444 surfaces) resulting in workbench refusing to save my new geometry preventing me from sectioning my model, thus preventing me from defining separate Rosette directions for the left and right side of the model.
Is there any way around this geometry limit?
Alternatively is there anyway to ensure ACP models the laminate inwards for both the left and right sides of the monocoque?
November 23, 2017 at 7:39 pm
SubscriberYou need to access an ANSYS Research license instead of the Student license. Does your University engineering lab have a Research license?
November 24, 2017 at 7:57 am
Vishal Ganore
Ansys EmployeeAre you a part of any student competition team?
January 22, 2018 at 10:19 am
Vishal Ganore
Ansys EmployeeHere is the feedback I got from one of my colleague:
The lay-up direction is not governed by rosettes in ACP. Builiding in two directions (upward and downward for example) can be achieved by using two Oriented Selection Sets with opposing orientation directions.
A Rosette is used to define the in-plane 0 degree reference direction (yellow arrows). The orientation direction of the Oriented Selection Set defines your off-plane lay-up direction (purple arrows).
No need to change the geometry for this.
- Limitations of ANSYS Student
- When DesignModeler is a better choice than SpaceClaim
- Off setting lines onto surfaces
- Rosette direction issue due to Geometry limits
- Free ANSYS Research software for Student Competition Teams
- Meshing Problem in Explicit Dynamic-Roll Cage
- Applying Moments for the Revolute Joints in Explicit Dynamics
- workbench
- Ansys Composite prepost analysis
- Composite Material choice in ACP
2706
2142
1357
1144
462
