January 25, 2019 at 1:19 pm
bhanu34
SubscriberHi,
I tried to explore the option called rotate in Body transformation tool in ANSYS DesignModeler,
In axis definition section, I see two options i.e. Selection and Components, I just want to know what exactly is component here?
and could you please explain in brief?
January 25, 2019 at 2:16 pm
sathya
SubscriberROTATE is used to to rotate selected bodies about a specified axis and by a specified angle.
You can specify the axis in one of two ways as listed in the Axis Definition property.
Selection: You can specify the axis or rotation using a Direction Reference.
Components: Component definition for the directional vector used as the rotation axis and origin
You can choose to keep the original body by setting the Preserve Bodies option to Yes.
If the original body is not required, set the Preserve Bodies option to No.
January 25, 2019 at 3:03 pm
Rahul Kumbhar
Ansys EmployeeComponents are the vectors of the global coordinate system. For example if you choose z=1, rotation axis is z of the global CS. If you choose Y=1 & Z=1, rotation will be about both Y axis and Z axis.
January 28, 2019 at 4:19 am
Keyur Kanade
Ansys Employeefollowing links may help you.
https://www.youtube.com/watch?v=r4ewc2-e740
https://www.youtube.com/watch?v=jOU9CP3SOSU
if this helps you, please mark this post as 'is solution' to help others on forum.
February 4, 2019 at 4:54 am
bhanu34
SubscriberHi rkumbhar,
Thanks for the information
I just wanted to know why you have only used 1 for X, Y, Z?
and What does value 1 signifies here?
February 4, 2019 at 10:54 am
Ansys EmployeeIt's a vector: so we just need to give the axis a value in this case. We could have used a value of 2 or indeed any number. If we'd wanted the vector to be at 45 degrees we could use x=1 and y=1 or x=2 & y=2: for 30 degrees x=1 & y=2 (might be 60 degrees!).
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5290
3311
2469
