March 25, 2021 at 4:26 am
ndvp
SubscriberHello,
I have this geometry, in which I want to rotate all three walls but have wall 1 and 3 adiabatic and wall 2 with a constant temperature. I tried to set wall 1,2 and 3 as a single wall, but I am unable to make the zone labeled wall 2 constant temperature. May I know how I could approach this problem?
March 25, 2021 at 11:19 am1shan
Ansys EmployeeHelloArray,nWhat is the exact issue that you are facing? Are you not able to select the surface corresponding to wall 2? You may have to split the surface using split body option under design in spaceclaim.nRegards,Ishan.nMarch 25, 2021 at 3:59 pmndvp
SubscriberHi Ishan, thank you for the reply. I am able to select the surface at wall 2 and assign a temperature and keep wall 1 and 3 adiabatic but I'm not sure how to rotate all three walls at the same time. Also may I know if I rotate only wall 2 if this would be an issue? I'm currently trying to rotate all three walls together.nRegards,nndvpnMarch 26, 2021 at 1:21 ampeteroznewman
SubscribernWhat is the purpose of rotating the walls?nHow does rotating the walls affect the solution?nMarch 26, 2021 at 3:41 amndvp
SubscribernI'm trying to model flow of sorbet through a mixer there's blades inside the cylinder, and I'm trying to rotate the walls to simulate the mixing. At section 2 the sorbet is cooled and the two other walls are adiabatic.nApril 1, 2021 at 4:40 pmndvp
SubscribernHello Ishan,nCould I get some help on this problem? I'm still not sure how I could go about it.nBest,nndvpnApril 5, 2021 at 4:43 am1shan
Ansys Employee,nWhat kind of analysis system are you using? It is not possible to include the rotating wall condition in transient thermal. You need to go for a CFD analysis using Fluent if you want to simulate the effect of mixing and fluid flow on heat transfer (something like). Please repost the problem under the Fluids category so that people of relevant expertise can look into your problem.nRegards,nIshan.nViewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2726
2156
1359
1150
462
