June 5, 2023 at 9:40 am
Samuele Luigetti
SubscriberHello everybody,
i'm trying to do a full harmonic response with a load asynchronous repect to the rotational velocity. So i'm using the tool rotating force to simulate this load but it' impossible to change the default geometry from "all bodies" to for example 1 or 2 components of the structure. Anyone can help?
June 6, 2023 at 10:55 am
Onkar P.
SubscriberHi Samuele,
You are correct we can't change 'all bodies' options, but you can specify where to apply the force in the model under the location tab in the rotating force details window, see the image attached below.
Also please refer to the following document- Rotating Force for further clarification.Regards
Onkar
4456
2955
1427
1322
